Can I use S0108B GLCD function in Fast AVR compiler?
NikZetaJones
Member level 2
Member level 2
Is anybody using Fa*st*AVR Compiler? I want to know if you can use the KS0108B GLCD function.
Thanks
Eze
sampling code sed1520 avr
hai,
look at the sample pgm
or help file
u get some idea
bye
glcd e1 e2 rw a0
Hi
Yes, FastAVR works great with KS0108 (=HD61202) graphic controller
(and SED1520 too...)
Here are lignes to declare two types :
'$GLCD SEP1520, data=PORTB, ctrl=PORTD, 122, 32
'$Gctrl A0=0, RW=1, E1=4, E2=3
$GLCD HD61202, data=PORTB, ctrl=PORTD, 128, 64, 2
$Gctrl CS1=4, CS2=3, DI=0, WR=1, EN=2
Code produced (ASM) is really readable and usable.
Regards
fastavr +ks0108
Hi there,
I agree with SC/MP. I did try the F*A*S*T AVR with the 90S8535 and the KS0108B GLCD. The graphic functions worked beautifully. I recommend it.
Hi. I discovered I'm using version 3.0.5 that support the HD61202 but not the KS0108B in the $GLCD declaration. It will still work if I use a KS0108B GLCD and the program says HD61202?. Thanks
Ezequiel
P.D.: Is any way to drive a KS0108B LCD with Code*Vision AVR? I have a driver for the SED1520. Could it be modified for the KS0108B?
Hi there,
I am confused. I did read from somewhere (maybe, from the FASTavr's manual) that KS0108 = HD61202. My compiler version is also 3.0.5, and my graphic LCD is KS0108B type. You have to declare (in the FASTavr's .bas file) that the graphic LCD's driver is HD61202 eventhough your LCD's driver is actually the KS0108B (and KS0107B). It will work.
HTH
HI, can any one pm me to get fastavr3.05?? :roll:
