Terminator3
Advanced Member level 3
Hello!
The first question is about using LTC6945 as 5ghz VCO. It is synthesizer+VCO chip, there is RFout pin. Can i use FET to amplify this output?
The second question about DDS,SYNTH,VCO chips. I want to clarify something out:
Synthezier chip to ... GHz - it can be used with external VCO to produce PLL (maybe with divider). So actually this chip itself can not produce RF output to ... GHz?
Synthezier+VCO chip to ... GHz - the same as above, but can be used without external VCO up to ... GHz? or with VCO+divider for Freq> SynthFreq.
DDS chip to ... GHz - can produse RF output, is it right?
The problem is, why we should use so many elements (external VCO, external Divider ic) to produce some frequency? I found some Analog Devices chip, but again requires external VCO, is there any simplier solution to get stable 5ghz?
