SparkyChem
Member level 3
- Joined
- Apr 22, 2010
- Messages
- 57
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Lima, Peru
- Activity points
- 2,084
Hello. I want to know if is it safe to use a battery holder with their wires attached to a 2.1 mm barrel dc jack for a radio.
The unit is center negative and as far I can tell from the users manual would require a source of 200 mA and 4.5 dc V. There are some adapters here and there but judging from the reviews most of them don't really supply the rated voltage and aren't as much reliable and add noise, which it can be problematic for a device where signal can be very susceptible to that.
So in short, is it safe?. I have these at hand and maybe I could use 3 AA batteries to fill what it is needed. But since it is center negative. I'm thinking that the common or ground (black colored wire) would be in tied to the inner barrel and the red colored wire would be tied to the exterior or outher barrel or the sleeve?. Is this okay?.
This thing of center positive and center negative it is a bit confusing for me. Can someone post a pinout diagram for this connector?. I couldn't find one which does clear my doubts, thus I thought someone here could help me with that.
