A’event and A= ‘1’ and rising_edge(A)are exact synonyms, anything said regarding the first also appies to the latter.
It's not generally prohibited, to use any signal, also from prior logical pcrocessing, as an edge sensitive clock. And it's particularly not a problem of fan-out. But the asynchronous nature of the design may imply some problems, depending onf the character of the more code here. A usual way to avoid them from the start is to use a synchronous edge detection instead of clocking a process with an unrelated clock. For a short signal, direct clocking may be the only option. But then, all input and output signals to the process have to be treated with caution, cause violation of setup and hold timing may result in unexpected logical behaviour.
