can i simulate micro controller based systems with altium?
madusnk
Junior Member level 1
these days i m doing a project with PIC microconts.can i simulate the whole systems with all other analog and digital components with altium?
thanks
Re: can i simulate micro controller based systems with altiu
Altium uses spice models to simulate. If you have models for your circuit elements - yes, you can simulate in Altium Designer.
can i simulate micro controller based systems with @ltium?
how can i find simulatiom modules for PIC ?
how do I download my programme to the simulation moddule in altium....
It sounds from your post as if you have no experience with circuit simulation. A PIC processor is a digital device. In order to simulate the various behaviours of a PIC Processor, you would have to write an appropriate model in Digital SimCode. You'll find a description of the necessary code and linking methods in "AP0139 Creating and Linking a Digital SimCode Model.pdf" on the Altium website.
https://www.altium.com/files/altium...ating and Linking a Digital SimCode Model.PDF
Simcode is an extension to Spice for event driven analysis.
The starting point for all simulation (analog, mixed, or digital) is the schematic. You would need a schematic loaded into Altium Designer with the appropriate models linked to the schematic components.
If you use PIC processors with analog circuitry, Microchip makes an online simulator you may want to look at: **broken link removed**
hi
is there anyway i can generate equivalent digital simcode of a vhdl code?
hi madusnk,
have u got succeeded in doing that simulation. I am also looking out for similar thing. To run my VHDL simulation and circuit simulation in Altium.
Any information you gathered on this topic would be much helpful for me.
Regards
