Can I simulate fractal antenna using only Matlab?
danesh
Full Member level 3
Full Member level 3
fractal simulation
is that possible for me to simulated fractal antenna using only matlab?
Re: fractal simulation
Hi Danesh,
Yes is possible. Once u have generated the structure in Matlab femlab can simplify things so you don't have to do the em coding urself.
Cheers,
Element7k
Hello, Danesh!
Fractal generator based on L-Systems
What kind of antennas you like to simulate??
Hi eirp!
I am planning on using fractal for a multiband antenna. Maybe from the DAB range to mobile phone range. Then bluetooth to hyperlan range. Will appreciate if anyone can give ur comments on this.
Cheers,
Element7k
eirp said:
Hello, Danesh!
eirp said:
Hello, Danesh!
i would like to simulate koch fractal antenna. rite now i have problem simulating it using microwave office, thats the reason i ask for second opinion. im quite new to this topic im pleased that ur willing to give ur opinions. thank
danesh said:
hi erip,
now I can say - forget about MWO.
It use uniform mesh so u need very fine meshing to include details.
I recommend you to use MoM simulator with nonuniform (triangular) mesh like IE3D. I did simulations of Koch mictrostrip patch antenna there.
Waiting for your comments....
Cheers,
eirp
eirp said:
danesh said:
hi erip,
I recommend you to use MoM simulator with nonuniform (triangular) mesh like IE3D. I did simulations of Koch mictrostrip fix antenna there.
Cheers,
eirp
the thing is my supervisor aspect me to run this simulation using MWO. i don really have much choice on software opitions. this is my bigest problem anyway if u don mind can u suggest me fractal antenna that can be simulated using MWO, thanks
danesh
Hi, danesh!
You aren't lucky guy if you're don't have other opinions than MWO :roll:
Built-in EM simulator is sufficient to do some particular and not very complex tasks with cooperating of linear simulator.
Well, you need to select fractal antenna with 90 degs angles only because the MWO's mesh is only uniform (rectangles only). This helps you to reduce computer demands. Thus try antennas like based on Minkowski curve...
Kind regards,
Eirp
eirp said:
Hi, danesh!
Kind regards,
Eirp
do u have any reference on Minkowski curve cuase all my reference is on koch antenna. if u have can u upload to me i already send the upload sever webpage particulars to u using private msg.
regards
danesh
