can I see the cross-polarization of the antenna in the CST!
xxgcatz
Member level 2
Member level 2
cross polarizations
I want to know if I can see the cross-polarization of the antenna in the CST simulation.It seems that many other simulation tools such as NEC ,IE3D can do that . Who can tell me ? Thanks a lot !
co and cross polarization in cst
It is hard! Because this software is lower than other in post-processing!You must learn VBA so as to solve problem in macros!!!
cross pol co pol, cst
Hi all!
Kunkun - why you think it's hard??
I think it's very simple :)
You need to plot rightly choosed components of farfield Etheta and Ephi (so not Abs!) !
For example:
Etheta, phi=0
Ephi, phi=0
Etheta, phi=90
Ephi, phi=90
xxgcatz - look into any antenna book for co/cross polarization definition!
Regards,
eirp
cross polarization
Thanks a lot to eirp ! I think I have known it , you are very helpfu to me ! Thanks again !
ephi plot cst
"EIRP" right but you can see it better if you use
the Cartesian plot one's plot the copol
and second plot xpol take the 2 data files
and combine them in matlab or excel.
In ver 5 you can do it simply by copy
and past
pl
Re: can I see the cross-polarization of the antenna in the
See:
