Can I reprogram P87LPC764 once it has been programmed?
ravi1488
Member level 3
Member level 3
India
Can I reprogram P87LPC764 once it is programmed? I have this doubt becasuse its datasheet shows that it has only EPROM. How can I erase that , I have a universal programmer.
Re: P87LPC764, need help
The P87LPC764 is One-Time-Programable (OTP), so once is programmed it can not be erased ..
IanP
:wink:
Thanks IanP.
Where I can find some sample C programs to configure P87LPC764? And is there any other IC available which is small(20-24 pin), have internal oscillator and low cost. I am just using it for timer application.
---------- Post added at 13:55 ---------- Previous post was at 13:39 ----------
Is P89LPC922 is a good option for that?
---------- Post added at 13:56 ---------- Previous post was at 13:55 ----------
P89LPC922 can be a good alternative for P87LPCxxx but if you intend to use it in a very simple application I'd go for PICAXE that can be programmed in the simplest-basic-dialect in virtually 5 minutes ..
IanP
:wink:
