Can I replace BF197 with BF199 transistor in this VHF amplifier?
Re: VHF amplifier
Yes, you can use BF199 instead of BF197 transistor. It will also amplify about the same around 100MHZ in that circuit your link shows because its unity gain transit frequency is around 400-500MHz.
    oasis4355
Re: VHF amplifier
Just another question,
When i'm dealing with VHF, the only parameter that i need to consider in the transistor is the unity gain transit frequency? or there's other parameter in different transistor that i need to consider as well.
Alex
Re: VHF amplifier
Other parameters are: Gain, Noise Figure, Linearity, Stability, Supply voltage, Current consumption.
VHF amplifier
I think freeacale's LDmos transistors are good chioce for the VHF PA design.
I have completed many PAs wroking from 30mhz to 500mhz, All used freeacale's transistors.
Btw, Point 9's transistor for VHF is a another good chioce.
