Can I modify an extracted view before I create the netlist?
pantic
Member level 2
Member level 2
Hi
I want to get a netlist from an extracted view (Cadence Virtuoso). But I want to modify a parameter before I generate the netlist, because the parameter is wrong. I've tried it but there are lots of error when creating the netlist and it is not created. One of them is the follow: ERROR: Netlister: the cellview XXX was modified since last extraction.
Does it mean that I can't modify an extracted view?
You can't modify an extracted view except re-extract it. The parameters should be calculated by extract rules.
Re: Can I modify an extracted view before I create the netli
re-extract the layout and you will get the modified one
How can I do it? I don't understand how can I get the extracted view I want from a layout that is the same as before. I want to change a parameter from the extracted view, not from the layout view.
Thanks for the responses.
