Can I leave the deep N-Well terminal floating?
ccw27
Full Member level 5
Full Member level 5
For P+ Poly Resistor is it ok to leave the Deep N-Well terminal floating? How about for Inductor? Can we leave it floating in general?
I ask this question cuz for p+ guard ring it is advisible to use a dedicated potential to bias it otherwise it increases coupling.
So if I don't have a dedicated potential for Deep N-Well P+ Poly Resistor or Inductor is it ok to leave the terminal floating? Will there be any side-effect? Will the device change characteristic once it comes back from fabrication? I believe there is no reverse or forward bias issues if you leave it floating. Any comments will be appreciated !
Thanks
Re: Deep N-Well Question
The model file for P+ poly resistor might hold answers. I've seen a small resistor that's formed between P+ and Nwell that has -ve TC and +ve VC. I've also simulated designed with bulk floating. They work OK but who knows what will happen after fabrication. Why not connect it if you can.
I heard that its recommended to tie to clean Vdd or gnd but if you don't have that at your disposition then you should leave the terminal floating
