Can I implement more than 10 FIFOs to XC2S100 RAM?
madjid
Member level 1
Member level 1
A question about Cores
XC2s100 containes 10 block RAMs,
is it possible to implement more than 10 FIFOs generated with CORE GENERATOR in this block RAMs.
Thanks.
Re: A question about Cores
If there are 10 BlockRAMs you can create 10 Fifos 512x36. I am not sure if you can create 20 fifos 512x18. You probably can.
I guess you know you can use Distributed RAM for your Fifos as well but only in X!linx devices, @ltera doesn't support it.
-maestor
