Can I have a triple boot PC with Fedora core 3, Windows XP and SuSe
safwatonline
EGYPT
hello,
i have Fedora core 3 along with windows XP using GRUB loader , i want to try SUSA , so can i triple boot ?!
regards,
A.Safwat
Re: triple boot
Yes, but you will need to install SUSE in different partition or second, or third harddrive. Than just add it to your GRUB loader.
    safwatonline
Re: triple boot
thnx for the answer but my question is how to add it to the grub?
thnx again
triple boot
you can install grub fro dos 4.0, it's setup is very easy, and you can install it on the windows platform.
    safwatonline
Re: triple boot
thnx again
Firstly, the Linux Installer may do this for you.
If it doesn't set tripple boot automatically, at least it can set double boot for you. After installing the second linux, you can merge the two /boot/grub/menu.lst file -- one from the first linux and the other from the second.
    safwatonline
Re: triple boot
If it doesn't set tripple boot automatically, at least it can set double boot for you. After installing the second linux, you can merge the two /boot/grub/menu.lst file -- one from the first linux and the other from the second.[/quote]
each grub install to MBR default, can you install two?
Re: triple boot
That would not work. Only one can be installed in MBR, for all other Linux oses install boot loader in the partition. Modify grub.lst to include booting from other partitions.
Re: triple boot
You don't need install two copies of grub. Grub supports multi-boot (not limited to double boot). The last installed linux usually will find all bootable partitions and properly set menu.lst file.
    safwatonline
