can i do circuit simulation in spectre like we do in hspice?
Analog_IC
Member level 2
Member level 2
i do want to use spectre for circuit simulation... bcoz hspice is not available to me.... help
Re: can i do circuit simulation in spectre like we do in hsp
certainly you can!
most of foundries surpport models for Hspice, Eldo and spectre.
You can use model for spectre to run simulation just like Hspice.
More details,please refer to Spectre Manual :)
Hi:
Actually, spectre is one of the simulators that most design platforms can support, such as Cadence virtuoso analog design enviroment. Different simulator will ask different model file which contains the collection of the design parameters with special symbol name. If you want to use spectre, you have to include the corresponding model files under the model path, and then you can use it as you use other simulators.
I have seen results for models after they are converted from HSPICE to spectre. The difference in results is minor.
but, when the design, most believe the hspice
