kkilambi
Newbie level 2
Can I use an NPN transistor for a Bandgap voltage reference.
I have used it just by inverting the circuit by connecting the NPN transitors to the power supply.
I am getting good nearly temperature independent bandgap voltage at 3.3 V.
But the voltage drops wit power supply naturally.
As I am simulating it for minimum and maximum cases of power supply it is changing proportionally with power supply. How do I deal with?
Thank you.
Thank you.
