Bindu boora
Junior Member level 1
Hi everyone.
I am working on a project to run a rickshaw using solar panels.The load it can carry is 761kg and net power is 1548W and rated speed is 21kmph.I have to connect solar panel to charge controller and then to battery and load.I want to know whether i can use 4 12V batteries in series with capacity of 92ah for 2000w BLDC motor?And in the spread sheet it is given the net power as 1548W.Is it the output power of BLDC motor?
