Electronics123
I have a DC power supply made for a 220v country but I have 120v where I live. Can I just wire-in a step-down transformer between the mains and its internal power supply or is there more to it?
Employing a step-down transformer to adjust a device designed for 220V to function on a 120V control source is indeed a doable solution. However, there are a number of variables you wish to consider:I have a DC power supply made for a 220v country but I have 120v where I live. Can I just wire-in a step-down transformer between the mains and its internal power supply or is there more to it?
Right I agreeGenerally, as long as its done on the mains AC side and the step-down transformer is sufficiently rated, you should be OK. Things to be careful of are the power rating and AC mains frequency. Most 120V countries use 60Hz mains and most 220V countries use 50Hz, there are small differences in the transformer design to cater for the frequency difference. If your power supply has a power rating on it (Watts or VA), use a transformer with at least that rating and preferably add at least an extra 10% to allow for inefficiency in the transformer itself. Using a step-down transformer with even higher ratings is not a problem.
Brian.
For what step up?I agree the topic here requires a step-up function, not step down.
How much watt does your dc power supply need?, and how much the step down transformer handle ?I have a DC power supply made for a 220v country but I have 120v where I live. Can I just wire-in a step-down transformer between the mains and its internal power supply or is there more to it?
