Can HSPICE accept parameter as string which used in .so file?
Hyunseok
Newbie
Newbie level 1
Hi Guys,
I'm trying to use HSPICE circuit file using external library(.so file).
I can't find what is the problemes in below process.
1. .so file
In this external library, I want to input 'string'. So Here is sample C source code.
#include <stdio.h>
#include <string.h>
static double char_match(char *c1)
     if (strcmp(c1,'test_string'))
         return 0;
    else
        return 100;
2. .sp file
With this circuit description, string can't be imported to "char_match" function
.option CFLflag
.cfllib './sample_cfl2.so'
.cfl_prototype char_match(param)
.param p1=str('test_string')
.param p2=char_match(p1)
And Here is the debug message
**warning** (sample_cfl2.sp:xx) Parameter XXX is ignored
 Using CFL library ./sample_cfl2.so
  **error** (sample_cfl2.sp:9) Illegal character in statement in column   xx : char_match(p1)
Can anyone help?
[moderator action: added CODE tags]
