grizedale
Advanced Member level 3
I wish to use LM5039 to do a 330W half-bridge SMPS running off 385VDC.
..LM5039 has a high side driver pin that can handle only up to 105V.
-if i want to drive a high side fet with an external high/low side driver rated for the 385VDC, then i presume i can just use LM5039's hi-side output by grounding the HS pin and driving like that.?
I am surprised that they put an internal high-side driver in it thats only rated to 105V.....nobody's mains voltage is that low.
