Can connect programmer kit149c to my laptop
jojokatada
Full Member level 5
Full Member level 5
kit149c
hi i just assembly a programmer kit from kitsrus.com kit149c i try to connect to my laptop but the message said board fail to respond. but i try in in my desktop it ok i can program some pic
in my laptop i select port 3
anyone have experience with this kit
please help appreciate
Re: progammer kit149c
Did you program the PIC on the board with the correct firmware? This firmware is inthe installation directory of your software.
CD.
the pic supply with the kit already preprogramed
Added after 2 minutes:
and the software is download from www.kitsrus.com
Be sure you've download the correct version of the software. Which PIC have you on your k149C board? If this pic is 16F628A, the software DIYpack25 doesn't work.
CD
yes pic16f628a i download Diyback22 as mention on the document come with the kit i try on my desktop it work but on the laptop it wont the message say board fail
hi crazyduck
do you think USB port of my laptop have problem?
please give me suggestion
appreciate
I've problem with FTDI driver on my PC. Try to uninstall the USB driver. Be sure you close the application before unplugged the programmer and it was a protocol with power, plugging, launch application to safe the driver. Look at DIYPACK help files .
CD
ok your suggestion is highly appreciated
progammer kit149c
Can this board support PIC18Fxx?
