It is not evident what you mean by 'internal impedance'. Do you mean the input or the output impedance?
What is the circuit intended to do?
Prof78
It is an amplifier circuit with a current input of range 1pA to 1 nA.But I don't have a source of that range.So I thought of providing a shunt resistance to it so that my source generating 1nA will allow some current in the pA range to the circuit giving an output voltage in the range 0-5V.Hence I need to find the internal resistance of this circuit
LMC6062 is deigned for a maximum (single) supply voltage of 15V. It will be damaged with +/- 12 V.The output voltage was constantly 11.78 volt.
Did you remove the 200k input resistor? If not then you will just saturate the output by amplifying the offset of the first opamp.
Did you really build this or did you simulate it? If you built it, where did you get the Giga ohm resistor? If you simulated it then why not use a current source for the input?
Keith
The first OP stage can be tested separately to check, if it's still alive (after reducing it's power supply).you have most likely blow up the LMC662
What it says, a difference. E.g. in your case, +12V - -12V = 24 V (> 16V!)Supply Voltage (V+ − V−) is 16V.What does that mean?
I know, that the Hamamatsu datasheets have much more detailed information, e.g about capacitances and parallel resistance.The Si PIN photodiode S5972 from Hamamatsu is found to have a typical dark current of 0.01nA(10pA).Can I use this as a picoampere source?.How can I find the R and C values for such a photodiode circuit ?
Thank youWhat it says, a difference. E.g. in your case, +12V - -12V = 24 V (> 16V!)
I tried the circuit with 1GigaOhm feedback resistance as well(Maximum R available in my lab).Still the output was nearly the same as input(say 4V o/p for input of +4V and -4V to LMC662)I would expect > GOhm feedback for a sensitive I/V converter.
Nothing that can be seen from your schematic diagram.Can anyone tell me what could be wrong?
Yes, the value sounds more reasonable. But the observed problem won't be related to feedback resistor value. Did you check the correct connection of OP input pins, and also for any hidden shorts with an ohmmeter?I tried the circuit with 1GigaOhm feedback resistance as well
