quiff_boy
Newbie level 3
I have a electric motor controlled valve in my truck's exhaust which on the press-hold of a 3-way switch either opens or closes.
to fully open, you hold the switch down for 7 seconds.
to fully close, you hold the switch up for 7 seconds.
The problem I have is that if you inadvertently hold the switch for longer, the gears grind and break.
I am trying to find an over-torque circuit that I could use to sense the "full open" or "full closed" position and kill the power.
I would have thought that this is a common requirement, but it seems not.
I was hoping a current sensor could be used to detect the over-torque?
The hostility of the environment (under a truck, a part of a very hot exhaust) and a sealed motor precludes anything fancy on the motor shaft for position sensing etc.
Any help would be gratefully appreciated!
Cheers,
QB
Cheers,
QB
