can anyone give e em simulation for lange coupler?
wjnbry
Member level 2
Member level 2
i want to design a lange coupler use em simulation.
can any one give me an example and these applications?
ADS,MWOFFICE,HFSS,CTS which software sould i choose?
I use Momentum of ADS. It is simple, nice and prety accurate.
For Launge coupler you have to add the gold thickness and of cource the air bridge )or bonds). To da so difine an air as a dielectric material and add a via layer in that air substrate. draw the whole conductive lines also in the via layer in order to creat the wales. In lounge couplers the walls hight has influence on the performance.
DJ,
Can you possibly post an example of your EM simulation of the Lange Coupler in Momentum ?
It is hard to understand your explanation...
Can you explain it some more ?
Thanks! :) :)
@DS,MWOFFICE,HFSS,CTS which software sould i choose?
hi try to use ie3d it has an example of lange coupler in its ie3d examples
regards
here ie3d examples of langer
open under ie3d 10.29
regards
