can any one help me????????
osha
Member level 2
Member level 2
egypt
i can't solve error in this code of nokia lcd 3310:
i use pic 16f877A
AND PIC C COMPIELRE
This is the project corrected, the file names were wrong and the table declarations must not be in capital letter.
be careful with the message functions it doesnt works with the piclite version compiler.
best regards..
MVB
    osha
what the meaning of(
thank u
WHEN I WORKED WITH THE NOKIA LCD I START WITH THE PICLITE VERSION AND THE FUNCTION :
printmessagetonokialcd("blablabla"); has problems i think that its because is a limited version, try it maybe i was wrong..
regards..
i used this code and put it on pic but there is no any output on lcd(nokia3310) what do u think about it?or why it did not work?
and this is my connection
draw of connection is ,please reply me???????????????????????
YOU CAN FEED THE uC AND THE LCD WITH 3.3V AND REMOVE THE R MODULES, OR YOU CAN DIRECTLY FEED BOTH WITH 5V, I´VE TESTED THE PROGRAM WITH THE LCD OF THE FIGURE (BOTH WITH 5V), BUT I DON´T REMEMBER THE MODEL OF THE MOBILE, TRY TO FEED ALL WITH 3.3 OR 5V AND IF NOT WORKS MAYBE THE CONECTION PIC-LCD ITS WRONG OR YOUR LCD ISNT THE SAME PIN CONFIGURATION OR ITS DAMAGED :(
