Hi!
using the calculator tool, you can calculate the dft of the signal but take the freq range 1kHz say on both sides of the harmonic you are going to calculated. Then you can use the peak function to get the harmonic. You can do this for calculating all the required harmonics by adding the output variables for each. Then by doing the parametric analysis by taking the sweep variable as the freq in this case, you can get the plot of each of the output variables you have added.
good luck!
