Can an Extended Kalman Filter be used on a noisy Sinewave
Ultimâ
If yes, what model is used? For example a moving target could have a state of
\[\underline{x}_{k+1}=[x_k, y_k, \dot{x}_k, \dot{y}_k]^T\]
...? I just can't get my head around this. Any assisstance would be great.
Re: Can an Extended Kalman Filter be used on a noisy Sinewav
I'm going to read this one too, so I can't say if it's precisely what you're looking for.
However, it (or its references) should be very close.
There are many covariance based (Capon and APES, or eigenvalue methods) methods that perform quite well. In your exploration, you'll find that maximum likelihood performs to a much lower SNR than many other methods (Kay, Tretter, etc).
Then there's the FFT, which will have the best noise mitigation for a stationary sinusoid. If nothing else, FFT results serve as a great "starting point" for developing a model to constrain the behavior of the various stochastic filters.
