Can AC and DC voltages be on the same pcb ?
auto_mitch
Full Member level 3
Full Member level 3
AC and DC on a pcb
Hi everyone!
I have built a control unit with an mcu which drives a few relays. The relays's contacts control (ON/OFF) AC devices. The mcu and the relays (24 Vdc) are on the same pcb at the opposite direction. Is that normal, being DC and AC Voltages on the same pcb?
Thanx
AC and DC on a pcb
Its alright as long as you isolate them properly. Use guard ring from DC supply ground to physically splitting the area. Relay is a good isolation device, there shouldn't be any disturbance, especially if you use relay controller circuit.
Re: AC and DC on a pcb
It would be advisable to keep AC and DC grounds separate
