funster said:hello, every friends:
my question is:
can a ribbon cable carry Ghz signals?
The reason?
best regards
sysco_stevens said:we usually don't use ribbon cable to carry GHz signal,
if you want to carry ghz signal, you can use high
quality coaxial cable to do it.
ribbon cable usually can be used for IDE interface
cable, because the speed is few tens Mhz.
if you use ribbon cable in Ghz area, the loss
will be greater.
my question is:
