Can a PDA control a PIC ?
wakaka
Full Member level 4
Hi there, I wonder can a PDA control a PIC??
Is there any available example, training kit or link??
Like I send some commands from a PDA to a PIC, then the PIC will start to blink an LED or do other task.
Wat software should i use for the PDA or wat should be the circuitry?
plz help....thanx......
Re: PDA PIC control
anyone??plz.....
Re: PDA PIC control
RS232 is possible on PDAs! You can use this!
Re: PDA PIC control
Goto Followng Link:
Regards
Tectona
Re: PDA PIC control
Google Search
And a search here
Enigma460
Re: PDA PIC control
Also pda's have infrared you could use.Very nice applications can be made with IR or RS232 but be prepared for some programming skills under Palm or WinCe SDKplatforms
PDA PIC control
I just found one chip, MCP2140 from Microchip. Looks like it can be used for communication between PIC and PDA.
But for PDA side, how can i send data? using wat software from PDA?Or the PALM OS has something like the windows hyperterminal?
Is there any example using MCP2140 with PIC, like blinking an LED or something?
Or other example like hard wired serial port from PDA to rx and tx of PIC??
thanx
PDA PIC control
anyone?
Re: PDA PIC control
Goto this link :
Regards
Tectona
PDA PIC control
i am Regarding this project,please help
PDA PIC control
dear,can you help me? i using pda connect ROBOT pass IR ỏ RS232 (serial port),PIC,MCP2150, but i can not connect ,why? i test pocketpc hp6365,code using at web pda-robotics.com
thanks
