camcad to Pad layout and to hyperlynx
1a2s3d4f
Member level 3
Member level 3
Hi everyone,
I would like to ask it possible to import from CAMCAD to Pad layout or to Hyperlynx. If is possible, will the constraint still remain the same during the conversion.
Thanks
difficult task......it will not come properly after conversion...
hi sivamani,
Thank you for your reply. I would like to ask what do you use to take file from CAMCAD to PAD layout. All I want is to simulate using hyperlynx. The manufacture file I have is .tgz. How would you read .tgz file to hyperlynx.
Please help if anyone know.
Thanks
conversion is a big task u need to model artwork in pads format to generate a pcb file..and it will not convert 100%.. need expert to do that..
If the Gerber is yours then u must be having board file also right?If not y ru planing to simulate gerber file which is not related to you..
