Cam350 v8 problems with license file
ZeleC
Full Member level 5
Full Member level 5
im having a problem with cam350 v8
everytime i start the flexlm asks for me to point to the license ,wehn i do everything works well but after i close the aplication and start it again it asks me agian to locate the lisence so i have to do that everytime i start it up .
please if somebody have this problem PM me please
thx
Re: Cam350
Hi ZeleC,
Try to append your CAM350 license to the C:\flexlm\license.dat
If does not exist, create it.
Also in lmtools in the "utilities" tab you can list the actual paths, and if needed you can add your own.
Normally the following should be listed there (List All Vendor Paths )
act_inc: x:\your_path\cam350v804\license.dat
rgds, Al
Re: Cam350
Make sure you have a proper entry in your environment variables listing. You can add more than one license file by seperating them with semicolons. Go to my computer, right click, select the advanced tab and select environment variables. Look for lm_licence_file in the upper box and add the path to your license file at the end of the current entry.
