Calling Functions from DLL
mesfet
Full Member level 2
Full Member level 2
Hi All,
I have a DLL file and the *.h file which describe the functions contained in the DLL. Can anyone tell me how to call functions in the DLL in C? I am using Visual Studio? Do I need to define something "extern ....." in my program? or I need to setup the compiler......etc. It is great if anyone has some examples.
Thanks,
MESFET+
If you do not have the .lib file that come with the DLL, you will be obliged to load dynamically your DLL :
here is a example :
assuming you have a DLL (in the right directory) called mylib.dll with the following function
int my_fct( int a, int b)
to load & use it (it's one way to do it...)
typedef int(*my_fct_proto)( int , int );
my_fct_proto Proc_my_fct;
HINSTANCE myDllHandle;
myDllHandle = LoadLibrary("mylib");
Proc_my_fct = (my_fct_proto) GetProcAddress(myDllHandle, "my_fct");
int result = (Proc_my_fct)( 2, 3 );
note : that msdn site has more than enough info about all MS ways of coding(/thinking...)
if you have the *.lib file for the dll, you simply go to linker options, add the lib file to additional dependencies, #include the *.h file in your source file, and you can call the functions
