Caller id using AVR MCU
benag6
avr caller id
I was doing a small mini caller id project using AVR2313 MCU + Cm8870. The problem is the telephone nos., displayed are not correct in sequence and also it is displaying only 4 numbers.
My assumption about the problem is interrupt problem. But How to increase the delay for every interrupt between numbers.
caller id avr
hi benag6,
I'm also willing to do a similar project, can you please give me the source codes for 2313.
    V
avr id caller
If you have full code in C or Assembly then if is not difficult to add time delay anywhere where you think you need it.
If you have only the hex code then the only think you can do is to try to disassembly the code and then try to modify it ..
    V
caller id avr
Caller id using AVR mcu,
Its easy to do this project using DTMF detection. U get caller id DTMF signals on the first call itself.
As i have done this project using other controller.
caller id with avr
Hi mitesh,
Can you please give me the full project details.
Thanks
    V
id caller circuit avr
Here is my assembly coding for avr callerid.
Circuit is quite simple.
1.)Connect Steering output pin of cm8870 to any i/o pin or int0 pin of 2313 for interrupting successive incoming call numbers.
2.) 4 bit Decoded tone output of cm8870 is taken as the registered numbers for every interrupt.
Thus every single number is registered by individual intrpt.
The coding includes LCD as well. Please try to identify the LCD pin connection also.
