Call labels inside function
gauravkothari23
Advanced Member level 2
Hi all..
I need to know how can i call a lable created inside main function uaing some other function
For example.
Void Main()
While(1)
Code here.
Label:
 While (1)
  Code here
Void function
While(1)
Code here.
Call label inside main().
In this above code i want to call the lable which is inside the main function from void function().
You can't, even if you use setjmp.h in your case (it is used to transfer control not to call code portions).
As you said, you want to CALL. So there must be a function there for ypu to call.
Create a function to initialize array and call this function from within main() and your other function as well.
Reactions: FvM
    FvM
