Calibre PEX netlist has port names with uppercase letter
ahmad898
Junior Member level 3
Ok I finally managed to extract the pex netlist out of calibre that matches with my verilog netlist. But, there is still one poblem. The netlist extracted from pex in spef format has changed port names with uppercase letter and this leads to the mismatch error in primeTime. My question is that what kind of setting I need to apply to calibre to aviod such change. You can see the output spef file generated by calibre pex whereas my verilog netlist is different in letters.
/// calibre pex netlist
*NAME_MAP
*1 B
*2 A
*3 CARRY
*4 MYOUT
*5 SUM
*6 C
*7 N5
*8 N6
//verilog netlist
module logic (
a,
b,
c,
sum,
carry,
Myout);
input a;
input b;
input c;
output sum;
output carry;
output Myout;
// Internal wires
wire n5;
wire n6;
wire n7;
wire n8;
At a guess, check the rule file for "PEX NETLIST SPEF PRIMETIME." The information in the SVRF manual says that the PRIMETIME keyword (among other things) outputs keywords and element names in all uppercase. You might try adding "PEX NETLIST UPPERCASE KEYWORDS NO" to your file if you are using a newer version of Calibre that supports it.
It is weird since I already added PEX NETLIST UPPERCASE KEYWORDS NO to the enviorment variables and the output of Calibre is the same and all nets are in uppercase.
