calibre error ( Flexlm daemon is too old)
Full Member level 4
Full Member level 4
calibre error
when I using calibre DRC on cadence, some error is show up like that.
license error : Flexlm daemon is too old
what is it?
I have installed Flexlm 9.5. but same error is appeared.
How do I deal with this error ?
flexlm daemon
i think the problem is the version of your 'mgcld' or flexlm. check both of them. mke sure use new one.
calibre license daemon
what version of Calibre are you using ?
calibre daemon
the latest version calibre need the v9.x flexlm daemon,so,you need copy the mgcld in installed calibre directory.And,use the new daemon start your license.
    020170
flexlm 9.5
what is it?
It is the reason that your mgcld can't merge your the lmgrd.
you may update your mgcld, and try it again.
good lucky
I once get this error.
You can do two step for that.
1.Make sure your lmgrd,which is used starting your license is the v9.5 and above.
2.make sure your license file,the DAEMON or Vendor line.Which have a path to the correct daemon(v9.5) mgcld.
Then,restart your license.
