quack934
Newbie level 2
Hello,
I'm not a specialized person in this field of wireless communications but i need to calculate the maximum distance 2RF systems can be apart. One of them will be placed in a eletric racing car.
I know the motor produces noise so if there is anyone who can help with this part too it would be awesome.
The motor is an EMRAX 228 medium voltage and the max rpm is 5500.
The data about the receiver and the trasmiter is this:
Model:E01-ML01DP5 (both of them have a shield case)
Power Supply:2.0V——3.6VDC
Communications levels:0.7VDD——5.2VDC
Maximum power:20dBm(about 100mW)
Gbps:250k,1M,2M, Adjustable
Emission current:95mA
Sinks current:20mA
Transceiver length:single packet:1—32 bytes,3 FIFO buffer
RSSI support: Does not support the true meaning of RSSI,Only supports packet loss statistics
Working temps:-30℃~+85℃
Working Humidity:<90% RH
Storage Temp:-40℃~+125℃
Operating frequency:2400MHz-2525MHz(1MHz step )
Receiving Sensitivity:-106dBm@250Kbps -96dbm@1Mbps -92dbm@2Mbps
If there is someone who can help me with the formulas and the calculations i would be very grateful
Sinks current:20mA
