jjzai123
Junior Member level 3
Hi guys, recently I've been studied about the stepper motor and I found 28-BYJ-48 motor is widely use in any application. According to the datasheet, the stride angle is 5.625 degrees / 64. Means it need 64 steps to reach 360 degrees, what if I make it to half step? Is the step angle become 2.8125 degrees and required 128 steps to complete a rotation? The datasheet is attached here.
HTML:
http://robocraft.ru/files/datasheet/28BYJ-48.pdf
