mohammadsh8421
Newbie
Hi guys
I am using the Saturn PCB toolkit for calculating differential pair impedance and there is a 6 to 10 ohm difference between Saturn and allegro calculations for the same stack-up and trace width and spacing. can anybody help me with this problem? Which one should I trust?
Also, which IPC standard does Allegro use for calculations? IPC-2152?
