actra
Member level 5
![Member level 5](/styles/images/ranks/dlevel5.gif)
- Joined
- Nov 9, 2004
- Messages
- 90
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- cairo [EGYPT]
- Activity points
- 851
if i used the vco in a pll system as a FM or ASK modulator...
when adding the modulating data before the vco...is it going to change the loop filter paramters of this pll system ?
imean if i designed a pll with certain loop filters parameters then added an external data source after the loop filter but before the VCO is it going to change the loop paramters that i designed at ? if so ? how can i caluclate the new paramters?
