nickthamma
Newbie level 5
Hello,
From my understanding of Ferrite Beads, it is typically specified by an impedance value @ 100 MHz. If I wanted to replicate the same circuitry as a Ferrite Bead (inductor with a resistor in series), how would I go about calculating the inductance. Looking at a particular ferrite bead's datasheet (**broken link removed**), I see that there is a DC resistance which I assume that this would be the maximum equivalent series resistance of the inductor. In addition, the datasheet also gives me the impedance value @ 100 MHz. Could I technically calculate the inductance knowing that the impedance of the inductor is (ZL = j*2*pi*freq*L)?
