[SOLVED] calculating capacitance of transistor gates
Zak28
Advanced Member level 2
Is it as simple as C= V/Q for this part maximum gate capacitance at 15v would be 119e-9/15 yeilding 7.93nF?
https://www.st.com/content/ccc/reso...df/jcr:content/translations/en.DM00052344.pdf
I'm not sure what your question is...
The output capacitance is acting as miller capacitance, thus ...
* Although the voltage at the gate changes only about 15V
* the voltage at the output capacitance may change 415V.
This causes high Q.
Klaus
Reactions: Zak28
    Zak28
This causes high Q.
Klaus
Hence max gate charge was determined at 415Vds was to obtain Vgs capacitance to obtain peak current which apparently is 7.93nF for 15Vgs at specified Ids.
I don't understand the purpose of deriving a capacitance value from total gate charge, because there's no physical capacitor representing the charge. The real behavior is better characterized by Figure 8, gate charge vs gate-source voltage.
Total gate charge can be used to easily calculate the per pulse gate driver energy and average gate driver supply current.
Reactions: Zak28
    Zak28
The effective input capacitance is calculated as in post #1. You have capacitance curves in the datasheet.
Reactions: Zak28
    Zak28
Total gate charge is useful to calculate switching losses
but treating it as a fixed capacitance will not be accurate
when it comes to transient switching behavior. Be sure
you want the right things.
Reactions: Zak28
    Zak28
This was to determine peak Igs current for gate driver which is 7.93nF for mentioned part.
Peak current into gate of transistor is simply V_driver/Rgate. No need for any capacitance value.
Reactions: Zak28
    Zak28
Is Rgate the series resistor between gate driver output and transistor gate?
It includes the gate driver's resistance and transistor's internal resistance as well.
Reactions: Zak28
    Zak28
