BADFLOPPY
Junior Member level 3
I found various Gaps filled with small chip or Insulators between two ferrittee pieces removing which the performance reduces. For example, in mosquito Trap (A Batminton racket type with three net with supply of 2.5KV, while I check spark in HV winding, just opened and rewind with proper insulation, I just peel off the small plastic piece and after fixing, found the frequency reduces and comes in audible range. As it is a self resonating Transformer (Heartley Osc.) surely the inductance increases.
I have observed this in several other devices too. Now my question, I am going to make an SMPS of 500VA to supply 75A at least at 5 volt for chemical synthesis. Now what air gap I should have to maintain, or how I can calculate? Using E50 or E65 cores, or if the had to go higher size as the freq reduces.
Moreover, if we put air gap or simply gap, then the magnitizing power required would be higher and the power loss may be higher?
Thanks in advance.
Thanks in advance.
