Prototyp_V1.0
Advanced Member level 2
Hi. Is there some in here capable to find any expression for the frequenzy of an modified version of an astable multivibrator.
I ask this because I found out that Vbe without diodes can reach a negative voltage that is almost the same value as voltage supply. That means if voltage supply is 12 volts, the npn bjt's probably won't last.
I have tried this amv on a breadboard, and it works the same way as original circuit. It oscilates faster than original circuit.
Anyone has an idea how to find expression for the frequenzy?
