waljit
Junior Member level 2
Hi All,
I am having trouble running a report in the Cadstar report generator and wondered if anyone could help.
My parts library has various attributes defined, these include the part "type" e.g. resistor SMD, capacitor through-hole, and also an "is_fitted" attribute that can be edited in the schematic to produce a BOM report for fitteds/not fitteds.
The problem I am having is I cannot seem to reliably read or use these attributes in the report generator. At first, I couldn't get one of them (is_fitted) to work at all. Then it seemed to start working - I am trying lots of things, so I am not sure what it was that made the difference. Then, I tried to get the component type attribute working - this is so that the BOM go can grouped by component, e.g. surface mount first then conventionals etc...
I cannot get this component type attribute working at all in the report generator.
I have tried making it of type symbol only, or of type symbol and component.
I have tried making it read only, or editable.
I have recreated the parts index.
I have reloaded all symbols in the schematic.
But I just can't get the report generator to see it or act on its value.
If I try and get the report generator to just display it, nothing is shown. Almost as if it is undefined.
Help!
Could this be something to do with the "lists" button in the report generator? I never used that before.
I have made sure that the attribute name is added to the list of attribute names, and that the values I am testing for (just numbers - 1,2,3,4) are also added to the list of text strings. No joy.
For testing purposes, I have reduced the parts library down to just one small file. It is still the same.
Any ideas anyone?
thanks in advance!
Waljit
Help!
Any ideas anyone?
thanks in advance!
Waljit
