Cadstar problem with shape GND layer
picnanard
Hello,
I have a problem with copper shape on GND layer.
After place this copper shape or ground plane if I move vias or net on this layer this error appear “via to copper”.
I’m search how can set dynamic copper shape.
Currently I use tab « shape default » and set « copper » and « action maximise copper » to place the ground plane.
I hope I'm clear.
Can you help me.
Cheers
DO NOT use "Maximise copper" unless you want a throwback to early easyPC lol.
Simply draw your copper shape then select "Add connection" and connect the copper to the net you want to use it with.
This is the reason why you are getting errors, because the copper is not connected to the net.
