Cadstar ----> Pads Translator
binu G
Advanced Member level 2
Bangalore
cadstar to pads
hi,
do any one experience in translating cadstar pcb file to Pads ?
Regards
Binu G
pads translator 2007
Hi Binu,
There are no direct steps for conversion,you need to convert the cadstar pcb files to gerber,later using Cam350 you need to export the files to Pads pcb files,sort of reverse engineering.
Regards
Ramesh
pads translator
try Pads Translator.... this is the readme....
pads schematic to cadstar
Hi Binu G,
i know an engineer with experience in translation of Cad star files into PADS. I have received the following info.
-First you need a last version of P A D S Translator. Supplied to Customers and available in support web of P A D S.
-Then you only need to run the prog.
-Remember the layers config are different for Cad star. In some configurations the converted layout, are in incresead layers in P A D S.
-If the original file from Cad str, not have strange config, the conversion are fine.
-The converter NOT work with OLD Cad star D O S version. Only for a recent Win version.
If you need other i contact this expert for you, skywalker.
