waljit
Junior Member level 2
![Junior Member level 2](/styles/images/ranks/clevel2.gif)
I have a problem with the batch process report created by Cadstar when batch processing some gerbers.
The problem is that the number of holes reported in the drill report section is incorrect and does not match the number that are in the excellon drill file. I have never seen this before, at least not to my knowledge.
For example in this particular design there are 50 holes of size 20 thou (assigned to drill letter "B"), I have confirmed this my separatley checking the excellon drill file. But the drill report table says that there are 62 holes of this size, i.e. the "count" field is incorrect.
The same problem exists for one of the other drills, the drill report table says there are 12 holes of size 161 thou when actually there are only 9 - again confirmed by a manual check.
All of the other drill counts look OK.
Does anyone know what could be causing this?
thanks in advance,
Waljit
thanks in advance,
Waljit
