It is not a very complicated footprint, and I would recommend that the OP find something close and modify it or just make one from scratch. Set you pad dimension properly. For placement of the pads and outline, you can do that with the command dialog, but for many users it is probably easier to set an appropriate grid (e.g., 1 mm and 0.1 mm or 0.5 mm and 0.05 mm). You can also edit the locations using the inspect/information button.
In Cadsoft Eagle have a good ability to quickly make yourself this item Ublox Neo-6m in the library, then use. Libraries in the other aren't always accurate or another grid, it's often a problem.
