Cadsoft Eagle library needed.
milan.rajik
Banned
Advanced Member level 5
Hi
I need Cadsoft Eagle 6.5.0 library for Goodsky GU-SH-112D T , LR-SH-112D relay and . If anybody ahve the library please zip and post it.
If anybody can make the library then I can pay for it. Please PM me if anybody is willing to make the library.
Datasheet links
https://www.goodsky.com.tw/files/New Datasheet/142-144 GU(revised).pdf
hii milan,
I can create library for that components,but i need some time for that.
thanks.
Sorry for late reply. If you can do it in a week or two it would be good.
None of your links work. Chrome browser/Win7
John
I am attaching the datasheets. Earlier the links were working and from yesterday it is not working. I don't know why.
Edit: Just now I tried and the links are working. Anyway I have downloaded all the datasheets for goodsky relays. If anybody need them then I will upload it and provide link.
  • 42-43 GS.pdf
  • 116-117 LR.pdf
  • 142-144 GU.pdf
Is GL (GL-S-112-DMF or GL-S-212DMF) a better relay for 230V 30A application than GU-SG-112D T relay? DC coil 12V, 230V 30A output contacts.
It fixes to PCB using screws (flange type) and the coil and output contacts doesn't solder to PCB.
https://www.goodsky.com.tw/home-applicance/70-gl
  • 140-141 GL.pdf
hii milan,
I m sending u the library of 2 relays(GS type and LR type).In GU type pdf there is 3 type of relay,let me know which1 u want.
  • LIBRARY.zip
Thank you very much kick. I will check your library and reply soon. In the GU datasheet's Dimension's page I need library for 1st relay type (T relay) that is for GU type and not for GU(Single Common) or GU(Unclosed).
Thank you.
See attached file. I chose 1 as scaling ratio in eagle and converted to pdf. I checked the pdf in Acrobat at 100% zoom and the relay footprint sizes are big.
Edit: Your libraries are fine. I chose actual size in Foxit PDF Reader and the relay fits to the footprint.
